2009 Vision CB/Intercom
hdfed
Posted 2010-12-09 10:55 AM (#75060)
Subject: 2009 Vision CB/Intercom
Orlando
The dealer installed a CB/Intercom on my 2009.  The bike does not register that the CB/Intercom is there.  The headsets will give sound for music only, but you only have one volume level and can make no adjustments.  No intercom either.
The dealership is waiting for Vistory to respond.
Any ideas?
ScoreBo
Posted 2010-12-09 11:40 AM (#75071 - in reply to #75060)
Subject: Re: 2009 Vision CB/Intercom
Northeast Ohio
Please tell me they installed the communication cable...
Victory Motorcycles Audio Wiring Harness 2008-09 Victory Vision - pt# 2876143
Edited by ScoreBo 2010-12-09 11:48 AM
hdfed
Posted 2010-12-09 12:04 PM (#75072 - in reply to #75071)
Orlando
Just sent that question to the dealership.  Would that also keep the headsets from working correctly?
ScoreBo
Posted 2010-12-09 1:15 PM (#75085 - in reply to #75060)
Northeast Ohio
The cable connects the CB (which also provides intercom functionality) to the radio unit, so I would say yes. We all know that radio and module firmware mismatches can cause weirdness like reboots, irradict behavior, etc. I don't ever remember reading anywhere that a module (XM or CB) isn't seen on the radio.
If you have the bike, you can see if the radio diagnostics recognize the CB.
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=2442&pos...
While I cannot personally confirm this, others have stated that the 2010 and newer require a different CB as Vic upgraded the radio. See Man314's post about halfway down. I am wondering if you possibly got a 2010 CB and it is not compatible with a 2008 radio.
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=5601&sta...
Either way, the dealer needs to sell you a working solution.
Edited by ScoreBo 2010-12-09 1:16 PM
Posted 2010-12-09 4:55 PM (#75096 - in reply to #75060)
I had the first Vision that my, Dealer Now Out of Business, installed the CB/Intercom on.
They did forget the Connecting cable.....xxxx143 and then tried to make me pay for one. I had to show them that it was on the original invoice and then they said ... Oh, thats ok your bike is ready now.
Ride Safe
LIVV
Posted 2010-12-09 5:21 PM (#75099 - in reply to #75060)
Nalcrest, FL United States
What happens when you push the button on the switch cube for the INT/Comm.? When you scroll through the dash button does the CB volume or channel adjust show on the display?
hdfed
Posted 2010-12-09 8:08 PM (#75119 - in reply to #75099)
Orlando
Noting happens.  It shows no CB on display.
Posted 2010-12-09 10:28 PM (#75124 - in reply to #75060)
Make sure you see "Wiring Harness Item # 2876143" on the list of products installed. This is the correct part for the 2009 Vision.
After you get this taken care of you might consider this modification. Swapped Controls for the Radio and CB
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=5010
Ride Safe
Posted 2010-12-09 10:38 PM (#75125 - in reply to #75060)
They could have ordered the "CB Harness ? Victory Vision Item #: 2878064" which is for the 2010 and 2011 Visions. This would be wrong for your 2009.
Ride Safe
Edited by radioteacher 2010-12-09 10:43 PM
LIVV
Posted 2010-12-10 5:27 PM (#75188 - in reply to #75060)
If they ordered the harness for the 2010 they could not have installed it. The connectiond are not the same. How do I know this you ask? I ordered the CB/Int system from a dealer and installed it myself. They sent me the harness for 2010. Imposible to conect to the 2008/2009 CB unit
Posted 2010-12-10 7:05 PM (#75197 - in reply to #75188)
LIVV - 2010-12-10 5:27 PM
Good to know. Thanks for the info.
dwenz58
Posted 2011-05-02 9:58 PM (#85384 - in reply to #75060)
Subject: RE: 2009 Vision CB/Intercom
I just finished installing my CB/Intercom setup and I am having the exact same problem. I thought maybe I didn't connect everything correctly. No volume control, no CB display, so no channel control or squelch. I can speak in the mic and hear myself. I can hear the radio also, but aboslutely no control.
srredbead
Posted 2011-08-08 9:33 PM (#92963 - in reply to #75071)
Milton, WA
Has anyone found a solution yet? I just finished installing mine and have the same problem that has been reported here. When I run the diags on the radio it reports all switches except passenger volume up, I verified that the switch is bad. The radio reports 5.21A BB 5.14A, 1. It does not show the CB at all.
GunSmoke
Posted 2012-01-08 4:18 PM (#104999 - in reply to #75060)
Bridgewater, MA
where did the actual CB unit get installed on the bike?
Posted 2012-01-09 1:14 PM (#105063 - in reply to #75060)
The normal install location for the CB is under the floor of the trunk.
baadawg
Posted 2012-02-22 6:29 PM (#108328 - in reply to #75060)
Chattanooga, TN
I have a related question, but not completely related and hoped you guys could offer some advice prior to me beginning work. To start with, I have an 08 VV Tour and just purchased a CB/XM combo off a 2010 XC. Now I see the part numbers for everything is different. The only similarity is the CB wiring harness. So, I'm thinking about selling the XM unit which is specific to the XC and finding a 2010 or newer Vision radio for my bike and using the cb and harness. I've heard that the radio is an direct replacement, plug and play, but don't know this for sure. I really like the idea of having a newer radio, cause I love my bike and that's really the only thing I would want a newer bike for. Anyone else have any experience relating to doing this?
baadawg
Posted 2012-02-22 6:33 PM (#108330 - in reply to #75060)
Chattanooga, TN
What the hell, I just started a new post if any of you want to respond. Thanks.
